Originally posted by nickb
View Post
Cathode Follower Reverb Circuit
Originally posted by Mike Sulzer View PostYes it can, if you have both sufficient voltage and current capability. I once suggested on the MIMF electronics forum that if you had a suitable power supply voltage available, you could use a one chip audio power amp as a general purpose tank driver, adjusting the series resistor as required for the particular tank impedance. I got thrown off the forum.
Back to the original schematic, an IRF820 Source Follower can be made to drive an 8E tank.
The 470pf / 1M input combination is taken from the classic Fender design. If you connect it ahead of the tone stack, you may want to go with a smaller input capacitor.
The 4.7K resistor in series with the tank alleviates the rise in current as the frequency decreases below 1KHz, but it also makes a voltage divider that requires 25Vp on the Source to get 4.0Vp at the tank at 1KHz. A smaller resistor in series with the tank would require a Source resister smaller than 30K which would cause the IRF820 to draw more than 8ma. I wouldn't want my SS reverb driver to draw more than 8ma.
This driver will supply an 8E tank with more than the recommended nominal current, but not a whole lot more before the signal at the tank starts to distort.
Originally posted by 66 Kicks View PostBack to the original schematic, an IRF820 Source Follower can be made to drive an 8E tank.
Did an amalgamation of some past ideas. In tweed position of the first switch you get a 5E3 type input and the second switch goes between a Tremolux 5E9A (paraphase PI) or 5G9 (Long Tail Pair fixed bias). The other position for the first switch would be for a Blackface amp, LTP for a cleaner sound, Paraphase for a little unbalance. Power supply values need to be worked out, originally was going to go 6W6GT for the power tube but may do a 6K6GT. Guessing the reverb as shown might be a problem for the Tweed position and anticipate putting it across the 1M resistor between the two switches for BF mode. A little more complicated amp than I originally was going to do, I wanted to replace the BF/Tweed Champ I gave to my brother and have reverb added.
