First, the reverb works, but has a "ringing", almost "oscillation" over riding the signal. It has an Accutronics tank with no part # other than 1122 stamped on the chassis. Both input and output transducers measure 186 ohms DC. Typically you measure around that at one jack, and close to zero on the other. Everything else checks ok. I've never measured this on a tank, they typically work, or one of the transducers opens. I'm suspecting the tank, but what to replace with? It's a long tank, 2 springs.
The tremolo optoisolator on this amp is just a small square black box. I think it's toast. I measure ~4Meg ohms across the neon bulb. I have a new optoisolator on the way, the typical Fender style with the shrink tubing over it. My question is, should I add a couple of resistors to the optoisolator part of the cct. When comparing to a typical fender, I'm using a Bandmaster for comparison, there is a 100K in series with the bulb. I suspect to limit current. There is also a 10Meg ohm across the bulb and resistor. I want to make sure the bulb is running within proper parameters. Would you add these resistors?
