Is there an argument against pulling two of the four tubes (either the two outside or two inside) in a Marshall 100 watt or Fender Twin to lower the power output?
pulling two tubes in a 100w amp?
Not arguments, but considerations, the impedance settings will no longer be correct as labelled. By pulling 2 power tubes, you double the impedance on the primary side, so for proper matching, you should also double it on the secondary side. This means running into a load double the impedance stated on the amp (or double what the original load impedance was).
A second point is that you are reducing the current drawn from the supply, so heater and HT voltages may rise. This should not be a problem unless filter caps have voltage ratings too close to the supply voltages. So for example, if you had 450V on 450V rated caps, removing a couple tubes could result in having more than 450V sitting on those caps.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by Randall View PostIs there an argument against pulling two of the four tubes (either the two outside or two inside) in a Marshall 100 watt or Fender Twin to lower the power output?
No argument against. Lots of "100W" Mesa Boogies have a half power switch that does lifts 2 cathodes off ground. They don't say much about compensating by speaker load adjust, but that doesn't mean you can't do it, say run 8 ohms off 4 tap.This isn't the future I signed up for.
To further complicate the issue, some will leave the impedance mismatched for further power reduction. Maybe that's why Boogie does it that way. Depends on the particulars I guess, I wouldn't chance it with a Marshall running full tilt (or beyond).Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
I think "half the impedance selector" leaves too much room for interpretation. It could be taken to mean set the impedance selector to half of the speaker load, or it could be taken to mean load the amp to 1/2 of what the selector is set to. Maybe "double the load" instead?
Also, it should be noted (and Leo alluded to it), this is not going to make the amp 1/2 as loud. The difference will be only slightly noticeable."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
If it's too loud you could sub in a 12AY7 for a 12AX7. This will reduce preamp gain so the sound might be different than you want but it's the cheapest and most easily reversible mod. Might be worth a try.
For a 100 watt amp to be half as loud, you would need to go down to 10 watts. Mostly, reducing to 50 watts just lowers clean headroom, not much overall loudness.Turn it up so that everything is louder than everything else.
I've always wondered about lowering the attached speaker impedance. The fact that you're also halving the current going through the OT (more or less, depending on the actual load) means it will be under less stress from a heating point of view. If the OT output side reflected impedance is double the load, I imagine the peak voltages could be higher than normal, but is 2x or 4x normal VAC an issue for the wire normally used? (As opposed to open circuit which would be a lot higher?) The advantage of mismatching would be to reduce the output power even further, of course.
Naturally it's a personal taste thing, but I never liked the sound of overdriven output tubes strapped as triodes as much as the normal sound of pentodes/beams.
Originally posted by mhuss View PostNaturally it's a personal taste thing, but I never liked the sound of overdriven output tubes strapped as triodes as much as the normal sound of pentodes/beams.This isn't the future I signed up for.
