In the Fender AA1164 Trem Schem...the one that uses 1/2 of the AX7. Is there any reason I should not start with the same component values.?
I am wanting to use that Trem Circuit with a 6SL7, but not sure if I can just do a straight substitution.
Guess I need to get the B+ and Cat Voltage numbers.?
Thank You
The Cathode is 2.5 VDC
The plate is only at 210 VDC
This Is Not a Fender circuit, and uses 2x 6K6 for the power section. Can I make this Trem work with only 210 on the plate.?
Thanks
Thank You
Thanks
