Hi all,
After being away from tweaking amps and this forum for a long spell, I've come back to the fold ( A lousy excuse for being away really, work.. and say it's not so, radio control airplanes. oh the horror! )
I also started playing Bass with some friends, and have decided to build a 2xKT88 amp. Volume isn't an issue, as we'll never play anything more organized than BBQ's and Birthdays.
I'll be using hardware I already own ( MM 50 4550JT-G1 PT, Dyna-Clone A431S OT, Weber 100 watt chassis, nice 100 watt Marshall style cabinet, and the usual suspects for the rest. None of my collection of Mustards will be in this one, I'll take the clean route for caps and put in Orange Drops.. Not that Mustards aren't clean.. Saving them for Marshall clone projects ).
My original plan was to build a 5F6-A, and sub KT88's.
Looking at Marshall's schematics ( the closest thing to the 5F6-A with KT88's I could find ), I saw that the phase inverter is tail-less, and the tone stack is moved to the middle of V2.
One obvious point here is that the Marshall is a 4xKT88. Another is KT88's take a good swing to operate, or so I've read.
Since I'm only driving two KT88's, could I get away with simply applying them to the original 5F6-A circuit ( given I'll be going the UL route, utilizing the Dyna Clone's taps and modifying the power supply accordingly )?
Would it be better to build a Marshall 1966, but with two KT88's?
I should mention the rectifier will be 50 watt style full wave, not a bridge, and I'll have a good chunk of filtering, 400uf for plates/screens, 200uf for the PI, 50uf each for V2 and V1.
Your asking, why not just build a 4x, since we all know Bass needs all the power you can get?
Purely economics I'm afraid. I don't normally compromise on projects, but recent changes in my sweetiepie's employment dictate That I go on the cheap for a while. I've got the stuff mentioned above, not using any of it for anything, and as mentioned above, don't need gobs of volume.
Whata Ya'll think?
Many thanx,
Bill
Whata Ya'll think?
Many thanx,
Bill
