Peavy has discussed the effects of output transformer saturation here and there, for example: http://peavey.com/monitor/pvpapers/Chapter7.pdf. I think what he writes is not correct, but perhaps I am missing something and someone could tell me what it is.
Here is why I think transformer saturation cannot be the big deal he makes of it:
A relatively simple discussion here: Practical Considerations - Transformers : Transformers - Electronics Textbook shows (in the section on core saturation) that saturation is a frequency dependent thing. For example, if you design an amplifier so that the OT just saturates at 80 Hz at the maximum possible ac voltage across the primary (assume push-pull so there is no dc) then it does not saturate at 160 Hz. So for guitar we have two cases:
1. Single note playing. If the fundamental of the note has a lot of power and is low enough in frequency, then saturation can occur. But there is some frequency above which there is no saturation.
2. Playing chords. We have a wide range of frequencies present at once. Thus the power at the low frequencies at which saturation might occur is too low to cause saturation, the total power summed all frequencies being limited, of course.
So this statement
"A little known aspect of output transformers is that their frequency response tends to drop off rapidly at both the high and the low frequency EXTREMES as the signal level approaches “saturation” of the core. This is a “dynamic process” which means that it is CONSTANTLY CHANGING with the frequency and amplitude of the driving signal supplied by the valves.In normal operation, frequency response is usually reasonably flat, but as the signal approaches saturation (maximum output) the extreme ends of the transformer’s bandpass tend to drop considerably, but in a “dynamicfashion” (meaning that the transformer’s “bandpass characteristics” are CONSTANTLY CHANGING!). "
seems to have no basis in the real world. That is, the concept of the signal level approaching saturation makes no sense, unless severely qualified to the point that this dynamic filtering does not happen as he says it does.
So this statement
