Hi- assuming its relatively similar in terms of wear/ 'push' on a set of 6v6's (in my case/ a Dlx Rev) having the gtr vol low or high WITH the amp max vol 10.. I think its generally same wear..
& if I want to keep the amp simply flat-out, & just use the gtr vol (bc I believe yous gets the best tonal results like so) mostly in my case gtr vol 2-5 say.. how long is it safe, or usual say, to keep the amp at max?
With no experience of using an amp dimed (Ive always tentatively put it at 3 or 4, only occasionally going into OD at 7 say) I have no knowledge of the useability of an amp in this max state, & I guess in particular Q is the set of power tubes/ how long they might last, &/or how happy they are being pushed like so.
Thanks, SC
Thanks, SC
