I've built mini amp with tube PCL86. There is 1/2 12AX7 triode and pentode similar EL84 inside this tube. A little problem is filament voltage because it's 13.3V / 300mA, not usually 6.3V
So I made filament as DC voltage using voltage doubler from 6.3V winding (2x diode, 2x 1000uF capacitor, 15Ohm resistor and next 2200uF capacitor with grounded - point ). All ground method is - from anode voltage rectifier, ground from pentode cathode RC, - from last filament capacitor connected together in one point, then next wire from this point to triode cathode RC, last anode voltage capacitor connect near input and input jack grounded to chassis. I've used it this way before in other amp and it works well (only filament was AC with two 100 Ohm resistors and grounded common point)
Heater voltage value is OK, all works but there's some strange hum, not 60Hz hum but rectifier like hum in signal.
I don't know if it's because of wrong filament groud method or capacitors have to be bigger or some other uknown reason.
I thank You very much for Your advices
