OK we've all come across microphonic tubes - tap 'em and they make a tinkling sound come of the speaker.
Now, here's a new twist -"speakerphonic" tubes. I'm struggling to find an appropriate antonym. These are tubes that make an audible noise when you apply a signal. Yup. You heard it first time and right here on MEF. Jensen -look out!!!!!
Here's what happened. I built a tube tester that does 18 at once. it applies the power by switching the cathode with a FET on for 80uS. It's all happily working away when I notice a faint tinkling sound and it's coming from the tubes. The bigger the voltage/current the louder it is. I haven't come across this in any of the literature. I haven't looked very hard either to be honest. I guess the electric field exerts a tiny force on the elements and they move slightly a bit like an electrostatic speaker. The precise converse of being microphonic. If I blow the dust of some old textbooks I should be able to estimate the forces.
I should point out that these were not what I would consider microphonic tubes as I had pre-screened them to avoid testing those that are.
I can't possibly be the first person to stumble onto this. Someone else out there will know more. But it does beg the question that this might be a more controllable way to test for microphonic tubes.
