Hi,
I'm looking to replicate the reverb circuit from an existing amplifier, as I want to utilize an extra tank that I have. It is a different model tank, however, and some funky audible artifacts are present when using it with my existing amp. Hence, I wish to build a circuit from scratch and tweak it to suit this tank. Please be aware, I love spring reverb and couldn't do without it, so this is a labor of love.
What has prompted this query is that I can only source 12V diodes at the moment, and I wish to obtain a fundamental understanding of what's going on so I can build it reasonably confidently.
My main questions revolve around the basic regulated power supply, and pertain mainly to the relationship between A) the voltage output from the rectifier, B) the relationship between the 47ohm resistors and their zener diodes.
Here is a schematic of the power supply:
I have measured the output of the rectifier at around 15.5vdc.
From what I understand, the zeners are there to 'clamp' the voltage to 10V in order to allow for, e.g. fluctuations in wall voltage.
The questions that are driving me mad are:
1) Is the primary purpose of R62 to drop the volts to around 10Vdc, or drop the current to stop the 10V zeners from overheating, or both?
2) If R62 wasn't there, would the zener hold the volts at 10V anyway?
3) If the wall voltage drops somewhat due to demands on the electricity supply, and R62 drops the voltage below 10V, what does that mean for the zener and its role in all this?
4) Does the volt drop across R62 have to come down to a point where it is reasonably close to 10V? Or 10V exactly ideally?
From these questions you may get an idea that my main confusion is, re: R62 and the zener diode...where does one end and the other begin?
Thank you for any and all responses.
Mitch
Mitch
