I've got some questions about clamping cathode voltages using the zener mods. From what I've read the use of diodes to clamp cathode bias voltages was first described in R.E. Lang's 1960 patent, and recently we've been talking about the use of Zeners instead of regular diodes in the cathode clamping circuit in order to provide what I think of as "transitional bias" or "hybrid bias." Essentially we're talking about cathode bias at low drive levels which progresses to fixed bias at high drive levels. In these circles I think the idea was first brought up by Kg, but it's become popular due a lot of work that Chuck H has put into refining the mod.
My questions are about the Ruby / Chuck Zener mods for a cathode biased EL84 application. I'm hoping that someone who is familiar with Paul Ruby zener mods and the Chuck H zener mods can offer some insights. Today I 'scoped the amp to determine what value of zeners I need to use with my existing tube compliment, but I'm just not seeing the things on the scope that I think I should be looking for when 'scoping the amp to determine the Zener values. The specific test bed that I'm working on is an Orange Tiny Terror. A schematic is attached for reference.
The circuit is bone-stock. The B+ supply rail puts 317 VDC on the EL84 plates.
The cathode bias circuit is comprised of a 120R + 220uF passive elements.
The quiescent cathode voltage is 10.9 VDC.
Effective voltage across the tube is 317 - 10.9 = 306.1 VDC.
These voltages put us right in the sweet spot for chimey EL84 tone.
I followed Chuck's recommendations in this thread and other threads on the forum -- I tracked the rise in cathode voltage as I increased the amp's output, watching for the onset of crossover distortion in the output so that I could choose the cathode ZV and then determine the Ruby ZV which should be a couple of volts higher. Much to my surprise, the crossover distortion that I was looking for never happened.
What?!?
Here's what I mean: the following scope snapshot shows a top trace that corresponds to one of the EL84 input grids, and a bottom trace that corresponds to the 10R resistive load that's connected to the amp's 8R output jack.
When the snapshot was taken, the amp was being dimed. The cathode voltage had risen from 10.9VDC quiescent to 19.3VDC with the PPIMV wide open and a reading of 15.45 VAC on the 10R load. Where's the crossover distortion?
I think that part of the reason that I'm not seeing it is that I'm intentionally driving the EL84 grids with a fairly clean signal. I'm driving a low amplitude sine wave into the amp's input jack, at values anywhere from 200Hz to 1000Hz. When the photo was taken the amp was being driven at 500Hz. The MV control was set wide open, with the gain control set to minimum in order to provide as clean a signal as possible out of the very gainy preamp section.
This type of waveform, with a sine wave that was beginning to look a bit triangular, persisted as I continued to drive the amp with a larger and larger input signal. When driving with a fairly large sine wave, the amp still looked like these scope traces when running full-tilt. Of course, as soon as I turned the gain control open on the preamp all hell broke loose on the output; everything went square because I was feeding a highly clipped preamp signal into the EL84 grids, and they reproduced it well.
What surprised me about this is that although everyone has referenced rather ugly crossover distortion in EL84 cathode biased amps (especially Paul Ruby), I'm just not seeing it in this test specimen. I'm seeing plenty of harmonic distortion, where the sine waves are becoming peaky and a bit triangular instead of nice and round, but I'm not seeing any of the crossover that I was expecting.
Of course, in the absence of crossover it becomes difficult to determine exactly how to size the cathode clamping zeners or the Ruby mod zeners. What am I missing???
Personally, I'm having doubts about my test measurements and I'm thinking that I must be doing something wrong -- it's hard to imagine that I just got lucky, and that the amp just happens to be operating with sufficiently low plate voltage, and high enough bias current to have eliminated the crossover distortion from the output signal. For that to happen this specimen would have to be sitting right on the "ideal" point of push-pull class A operation, where the tubes are biased exactly in the middle portion of their transfer characteristics, so that neither tube cuts off during any portion of the cycle.
Did I just get lucky or am I completely missing something? Either way, with these results I'm having a hard time deciding what sort of ZV might be useful. As it stands now, I can't see how the Zener mod would really be helpful.
Anyone?
What?!?
Anyone?
