Fender 5F11 trem circuit
  • Fender 5F11 trem circuit
    Can someone help explain how the 5F11 tremolo circuit works? I see it involves half of the first 12AX7 and the bias voltage gets to the 6V6s via the depth control, but I don't fully understand how it oscillates.
    http://elektrotanya.com/PREVIEWS/634...5f11.pdf_1.png
    I started to write an explanation but Aiken does it better
      It is a low frequency phase shift oscillator.
      The trick is the caps that feed back into the grid.
      Over & over again.
      Lots of good explanations here:
      https://www.google.com/?gws_rd=ssl#q...req+oscillator
        Over & over again.
