One of the nice features in PSUD is that after plugging in the no-load voltage and the secondary winding resistance, you can vary the load on the transformer in your models. (unfortunately that web calc doesn't seem to have that functionality.)
varying load conditions can produce a huge difference in the voltages obtained, and PSUD is a very handy tool for that kind of modelling. As an example: PSUD makes it very easy to model the differences between biasing an amp into class A1 and into class AB. I've run into situations where a transformer works fine if you bias it into class AB1 and you assume an average duty cycle, but ends up being way under spec for the class A application.
in addition to the other considerations that have been suggested, such as cap values and winding resistance, I'd add that bias conditions could make a difference. some power transformers and output transformers won't hold up to class a operation. of course, it shouldn't be an issue if you decide to stay in class AB.
