First off, I'm a layman or aspire to be,
I've been experimenting with lowering plate resistor values im my marshall to say 47K and raising cathode resistors to like 3.3k then using a bypass cap. this is a two channel marshall 2205 from 1983. I was using a triode calculator on "adams amps" website and according to the program the output gain would be the same. Plate voltages have went from around 140v to 230v. The amp sounds much improved, maybe less distortion, but less buzzy.
Can anyone shed some light on the theory behind this?
I was trying to emulate voltages from the early marshalls. My el34 plates went from 480v to about 465v, still higher than most jcm800s.
Does raising the cathode values present problems at some point?
