I know the difference in feel they can make. I have tried different values and noted the difference in how stiff higher values feel. I have a 80uf cap in my preamp's first stages and a 47 at the PI and i tried another 80uf in series with the 1st cap to see how it felt at 40uf. i liked it but felt a bit larger might be perfect. Heres the question...i already have a 40/40/500v JJ cap but because i felt the 1st node could be a little tighter and because i would be losing 7 uf at the PI, i thought maybe i should go for a JJ 50/50 to keep the value about the same at the PI and raise the 1st node a but. Do you think i will feel the difference between a 50/50 and 40/40 or is that just too a difference at both nodes small to feel it? I know this sounds anal as hell but it's not a big deal, i just thought i may as well ask before wasting $.
40uf vs 50uf filer caps?
Are you measuring the caps to see what they actually are?
The tolerance on caps is not all that tight. For you to be able to hear a noticeable difference between 40 and 50 may be due to a wider spread in values than they are marked as.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostAre you measuring the caps to see what they actually are?
Consider that you may be hearing a difference in the caps' ESR rather than their particular capacitance value.
Also that the values measured using the tiny test signal from a meter with a 9V battery may be different to those exhibited by the cap in a high voltage circuit, especially when things have warmed up and significant ripple current is being drawn.My band:- http://www.youtube.com/user/RedwingBand
Ok, but that aside, all things being equal, in theory what would the difference be between adding a 3rd node rather than running V1 and 2 off the same node and upping the uf using only one node as far as tone or feel? (feel being the prominent change i'm sure, as tone doesn't really change so much with filters)
Originally posted by daz View PostOk, but that aside, all things being equal, in theory what would the difference be between adding a 3rd node rather than running V1 and 2 off the same node and upping the uf using only one node as far as tone or feel? (feel being the prominent change i'm sure, as tone doesn't really change so much with filters)
edit: some time spent with PSUDII might show a difference. In theory.If it still won't get loud enough, it's probably broken. - Steve Conner
I just quickly and sloppily (of course) tacked it in to see and what i notice is yes, a bit stiffer but not at all in a bad way and very little and by dialing down the highs a bit that goes away. What i really liked and have therefore decided to add it permanently is that it just sounds cleaner. I use distortion and roll the volume down for cleans and now when i do that the cleans sound cleaner and rounder. When i hear about more filtering equals less noise i never really associated it with that kind of noise. More like hum/buzz. The type of noise it seems to eliminate is the nastly bits around the note. Almost a staticy bit of garbage, and thats no longer there.
Different cap values will be felt as stiffer or looser where:
a) current demand varies a lot with music playing, with guitar picking if you wish, so voltage will vary more, and faster, with a smaller cap than with a larger one..
b) said voltage influences gain, such as in a pentode stage, when screen voltage is linked to the power rail.
Both conditions are met at amplfier power tube stage.
None is met at a preamp so 40 uF there will sound exactly the same as 50uF.
Only possible difference will be if the supply is very poorly filtered, has tons of ripple, such ripple gives annoying levels of hum .... but that´s not what we are talking here.Juan Manuel Fahey
The trick is limiting that. If you balance the number of triodes on a node you can give the amp more "punch" without making the transients overly hard, but as noted, the response will be more 'stiff', especially in response to fast transients like tremolo/speed picking. Power chords really hit you in the gut, but playing fast becomes more difficult.
There is always a trade off.
Originally posted by wizard333 View PostAs far as real world application, I've noticed experimenting with power supplies and giving each triode it's own filter, that the response becomes HARD. By that I mean, when you hit a chord, especially anything with low notes in it, it hit's your ears like a hammer. Super, super percussive on the transient, in a really unpleasant way.
Hi Guys
What you gain by giving each stage its own supply node is better note articulation and lower noise. That is, provided you also fix up the wiring so that each stage sees its own filter first. This tidying up eliminates most intermodulation of the supply and signal, and of signals that shouldn't be mixed.
Where the node voltages are fairly steady in a preamp on a DC basis, there is also a circulating signal current. There are then two currents effectively for each stage. Powering cascaded inverting stages from the same node provides an easy means for oscillation to occur.
The multi-section caps tend to be very low quality, with hgih or unspecified ESR, DF and DA - all deviations from being a perfect cap that all caps share, but electrolytics have more than others, and axials and multi-sections have to a greater extent than radials or snap-mounts. besides, multi-section caps ensure that currents mingle which otherwise should not, making it much harder o have the best performance possible.
I prefer stiff supplies since it is easy to add dynamic effects by adding and R here or there. Most guitar and bass amps are woefully under-filtered. TWs and similar have horrific hum-modulated outputs when they are clipped and this is easily fixed. The Komet is one of the worst amps I've heard. TUT3 shows how to wire an amp properly for best note articulation and lowest noise. It also shows how to soften the sound to taste.
Have fun
Interesting, that answers some questions i've had for a long time. Thanks 4 that.
Have fun
Originally posted by KevinOConnor View PostI prefer stiff supplies since it is easy to add dynamic effects by adding and R here or there. Most guitar and bass amps are woefully under-filtered. TWs and similar have horrific hum-modulated outputs when they are clipped and this is easily fixed. The Komet is one of the worst amps I've heard. TUT3 shows how to wire an amp properly for best note articulation and lowest noise. It also shows how to soften the sound to taste.
Have fun
I have universally found over-filtered amps to play stiff and have a decidedly unpleasant feel. If you know a way around that, can you be more specific on how you could use a lot of filtering and not get that effect? I have yet to ever see that on an actual amp.
I can't speak for kevin, but if i had to guess on how he would fight a stiffer supply i think there are many things in the preamp at least where certain circuit configurations will add a lot of sag while others will be stiffer. I can't give you specifics as to exactly what will do that because it;s a huge puzzle and one change will affect all other things and often to get there i have to make several changes and cannot say that the one that triggered that looser feel was responsible by itself because if i change any of the other things it then changes the whole feel again. In other words there are a lot of things that together might trigger it so itl;s near impossible to note what exact does it. Also i think larger value dropping resistors will help there.
That said, i'm not sure it;s even possible to counter a stiff supply to the point it feels as loose as it would at 1/2 the filtering (overall value wise that is) as keven suggests. I know approximately 1/1000 as much electronic theory as him on a good day, but i do know what i've experienced and while i agree with him that it can be countered, i don't think it can be brioght back to the same feel as lower filtering exactly. Just to some extent. I may be wrong but like you i have never been able to eliminate it, but i HAVE helped make a stiffer supply more acceptable via other changes, but not that i can say because as i said earlier it was just trial and error and i'm not sure exactly what did the trick. But in the end i have never been able to do it to a point i was happy enough with it to leave it there and always end up reducing the cap value overall.Last edited by daz; 09-27-2016, 12:56 PM.
Hey daz... You're a nut and a tweak!I hope you never change, but I also hope you're having some fun with it.
