First, for reference, a redrawn Matamp GT100 schematic - not great, but still more legible than the original scan:
![Click image for larger version
Okay, as you can see, Matamp used an RLC notch filter in the global NFB loop around the power amp for a mid boost when the presence was turned up. There are a few flags warning of stability problems, namely a bypass capacitor across the feedback resistor, a DC coupled cathodyne, and relatively large anode bypass capacitor on the driver tube. Still, I feel like trying this. I don't happen to have any inductors on hand, but I understand they're typically avoided in tube (guitar) amps as they're particularly sensitive to picking up noise.
But if all I need is a notch filter, why not use a bridged-T or twin-T?
This is one of those places where just being a hobbyist on the internet is a big shortcoming, while someone with any level of book-learnin' would be able to answer "well of course it [will/won't] work; obviously."
I'm worried about loop stability, more particularly if there's an effective phase difference between an RLC notch and a bridged-T notch. I took a peak at an online calculator:
http://sim.okawa-denshi.jp/en/RLCbekeisan.htm
http://sim.okawa-denshi.jp/en/TwinTCRkeisan.htm
and putting similar filters in, the phase plots don't look much different. The RLC notch is clearly of higher Q, but since we're talking about a NFB loop with maybe 9-10dB of feedback being applied, either filter is blocking a few hundred Hz.
Granted that this particular implementation of a presence control isn't very popular (and Orange moved away from this circuit when they started building their own amps to one using an inductor between cathode and grid of the driver triode, and eventually just to variable cathode bypassing of the driver) suggests it might be a silly idea or might not work very well after all.
Any ideas or tips?
Any ideas or tips?
