I looked in Merlin's book and Jack Darr also.
It is probably there somewhere, but i cannot find it.
When the 6.3 VAC winding has a CT, and that is connected to ground, there is no current through that CT.....right.?
So should it be OK to connect the B+ filter cap grounds to that Heater CT also.?
That is to say... I can ground the Heater CT and the filter caps to the same spot on the chassis.?
Thank You
Thank You
