I posted years ago about it. I used Weber transformers he sells for Champs and since I have only 8 ohm speakers I got the Weber OT with a 4 and 8 ohm taps.
I do know how to check the bias . Yet what I'm confused about is the screen voltage. If I check the Plate on the 6v6 to ground and the screen the same way the screen at idle is 9 volts above the plate . The OT has 250 DC ohms across the primary yet the screen has 1K ohms off the 1st 1K dropper . It seems the screen would be lower . If I look at the fender schematics of the Champ and vibro champ and bronco they all use the same PT and OT yet they all differ so much .
In order to read the correct screen compared to plate should I check them both to ground or to cathode or does it matter.
I never saw a Champ SF or Black with any screen resistor yet their schematics show the screen either the same as the plate or 2 volts lower and if you look at the B+ where the plates get the voltage the Bronco drops quite a lot with the same tranny's. So I can't say what the fender schematics relate to .
My main question is does it matter if the screen is 9 volts above the plate? I had real SF champs yet never checked what the screen was at I just checked the bias and kept them under the 14 watt 6v6 so the amps didn't sound so grainy and to keep from killing tubes.
