I think i will grab a Hammond large 17" x 8" x 3" aluminum chassis for my next build which is a 40 -50 watt possibly 2 el34 or 2 5881 & 3 12ax7 preamp tubes & more likely a solid state rectifier & single channel , maybe jcm 800 style or Trainwreck express & maybe a choke .My question is for anyone who uses these kind of chassis How big of an amp can you build using this size of chassis ? for now it will be a single channel but in future i may want to do dual channel with an fx loop .
What Hammond chassis for Marshall build ?
Originally posted by GainFreak View PostWhy bother? There are plenty of online stores that will sell you a ready to go punched chassis for a Marshall project.
shouldn't 16" to 17" work just fine .Last edited by copperheadroads; 12-07-2016, 11:38 AM."UP here in the Canada we shoot things we don't understand"
This book has a couple of amps with that size chassis (he uses a 2" deep instead of 3") including a Bassman. It has the chassis dimension layout for punching your holes, circuit board layout, bill of materials and all the rest of the info you need. It's not a kit but directions for a scratch build so you could do your homework and see which components you need to change for your JCM 800 since the original JTM45 was a Bassman copy. https://www.amazon.com/Building-Vacu.../dp/B004FKGVTA Here's another link in case the Amazon one doesn't work for you: Building Vacuum Tube Guitar and Bass Amplifiers Volume 2 by Tino Zottola - Guytronix The 5E3 uses a 10 X 6 X 2 chassis and the 1959 100W uses a larger one but the 50 watt model uses this 16 X 8 X 2(3).Last edited by DRH1958; 12-07-2016, 12:43 PM.Turn it up so that everything is louder than everything else.
I was eyeing one of these for the build.
https://www.cedist.com/products/chas...num-16-x-8-x-2
https://www.cedist.com/products/chas...-x-8-x-3-black
https://www.cedist.com/products/chas...num-17-x-8-x-3"UP here in the Canada we shoot things we don't understand"
Those 16 gauge Hammond chassis are too thin for heavy transformers. Even if you use big washers to spread out the load, they will eventually sink where the transformers are mounted.
I mostly use Watts Tube Audio (tubeamplifierparts.com) or Mojo, but I know how crazy shipping and customs charges to Canada can be!
This Canadian supplier makes 14 and 12 gauge custom chassis, and can pre-cut the IEC socket mounting hole for you, which is a major PITA.
I highly recommend the 12 gauge (.08 inches) for any Marshall project. I've never used these guys, but I've heard good reports on the amp forums:
Home
These are battens. They keep the amp from moving vertically and give you a handy place to mount a front panel:
Finished product:
I usually make one of the rear battens shorter to allow clearance for the PT, but if you keep the PT about 2 inches from the end, you can make both the front and both back battens full length.
Cheers,
Ken
