I have read numerous times from cognizant amp builders/repair-persons...that when you wire the filament string, you keep the "A" filament wire connected to the same pin on every pre-amp socket, and the "B" filament wire connected to the same other filament pin on the socket.
IOW, "A" wire to all pin 9's, and "B" wire to all pin 3/4's.
My question is - will it make a difference in the amount of filament hum not conforming to this scheme? If so, can you explain the principal involved?
Thanks!
Thanks!
