Finally got back into this amp, and there is noise it never had before.
I put a 1k 200mV signal into the amp. Followed it through, and it all looked fine until coming out of the PI.
The preamp and PI is 6SL7...and it is your basic Fender Vol, Tre, Bass, tonestack, and a LTP phase inverter. I did change to a new PI tube, but no difference.
When i put the scope on pin 2 of the PI (after the coupling cap) the positive sine wave is clipped. I changed tubes and it is still the same. I have never really looked at a PI before.
But i assume one side of the Sine should be Off/Clipped, and then just the opposite on the other wave.?
This does not look right does it...the photo with the clipped positive wave.?
What is causing this.?
Thank You
http://i.imgur.com/MAhx1oS.jpg
http://i.imgur.com/qQpsWqc.jpg
Thank You
