It's been a while since I last built anything, but now I've got this idea I just can't let go of:
A modular tube preamp, that contains tube gain stages in one box, and all tone controls (i.e. stuff that operates linearly, not only user-adjustable controls) in another, probably op-amp based box. This way I could build the expensive high-voltage stuff once, and try out different ideas, by plugging in circuitry feeding the gain stages with different signals. I could switch between different circuits and possibly even make a MIDI controlled version, using digital pots.
Looking at what makes tube pre-amp tone, there seems to be two crucial circuits: The basic triode gain stage, and the dc-coupled cathode follower. My idea was to put two triode gain stages, both followed by a clean ac-coupled cathode follower (for low output impedance), and two dc-coupled cathode followers in the "tube box", and simply provide in and out jacks for each of the four. You could then hook up the "tone box", which would implement various fixed filters, gain control(s), a tone stack, and a master volume.
Main concerns/questions I have:
1. Will I have issues with noise or stability if I have this stuff in two boxes like this?
2. Would using send-syle TRS connections between each gain stage work, or do I really need to plug 8 cables between the boxes to make it work optimally? These would be just short patch cables. Or is there some multi-poled connector that would work well for this?
3. Did I miss something else crucial, which would make this a stupid idea?
4. What would be the best way to make bias adjustable? Just carry a dc voltage in the signal, or put e.g. relay-controlled cathode resistors in the tube box?
5. I think I would be able to model any rather basic preamp with this, by just doing filtering in the "tone box". Of course it wouldn't be 100% identical to the original circuit, but very close. Or am I missing something?
Any feedback or idea is very welcome!
