I really don.t know how much the core is completly isolated, from a safe point of view.There is a capacitive coupling in between. Sure a crimp washer between core and end bell will assure firm contact, although saw a lot of PT which did not used it and end bells covered with a thick layer of unconductive paint. Even so,should conduct enough to blow the fuse and not keep the frame under voltage potential.
late edit: is not a "research", this thinks should be very basic and in consequence important. Unfortunately I haven.t a electrical formation and infos found are not in conformity with what I tested. The electrostatic screen tied together with HT center tap did less noise ,in my case, than tied to chassis to one of the transformer bolt. I haven.t a earth contact . So, should I use the electrostatic screen in this condition , or not ? IF Yes, where You consider should I tie it if I don.t benefit by earthing, please ?Thanks
