mosfet follies - cathode follower
  • mosfet follies - cathode follower
    Hello, can anybode gude me on this:
    - http://www.geofex.com/Article_Folder...osfetfolly.htm
    The part about mosfet cathode followers.
    1. The idea is that the mosfet follower amplifies the output current, providing lower output impedance. So it is much better than taking the output signal from the anode with a voltage divider, right?
    2. How to calculate the source resistor. It will set the maximum current consumption of the mosfet, right?
    3. The output voltage swing at the follower is going to be the same as the anode voltage swing at the gate, right?
    - I guess, the source resitor could be two resistors in series (voltage divider) and I will attenuate to the voltage I need.
    4. How to calculate the output impedance of the mosfet cathode follower? I guess it depends on the current set by the source resistor and the voltage swing.
    Regards
    1. Yes, it will have lower output impedance but it it won't attenuate the signal like a voltage divider.
    2. I'd use the same value as would be used for a similar cathode follower circuit.
    3. Yes, the output voltage swing will be the same as the anode voltage.
    - The source resistor could be two resistors but then you have lost the low output impedance of the source follower. To attenuate with low output impedance the anode resistor could be split and then buffered by the source follower.
    4. Output impedance is ~1/gm
      That's one way to say it. I'd modify that a little by saying that MOSFETs don't have a current gain; or rather, their current gain is nearly infinite. They have a transconductance, where a change of voltage on the gate-source, causes a current to flow in the drain/source. The gate of the MOSFET is so close to an open circuit that it takes very, very fancy equipment to tell them apart, so the tube anode is unloaded.
      The MOSFET source is a low impedance output, and is loaded by both its source resistor and whatever load is connected in parallel to the source. A signal on the source is loaded by both the source resistor and the output load, so the source signal voltage sags a tiny bit.
      The gate, being held almost perfectly to the preceding anode, does not sag, and so the voltage from gate to source sags a little - and in the perfect direction to make more current flow into the source from the drain. So tiny, tiny changes in the source voltages can make bit current changes through the MOSFET.
      And that gets us back to your statement: very high impedance to the anode? Check. Amplifies the current and provides low output impedance? Check, but in a slightly subtler way. Better than taking signal from the anode? If you are driving a load lower than 10x the anode source resistance, check.
      Yes, it sets the idle current flow through the MOSFET. The gate is held at some relatively fixed DC voltage, the source will be about 4-6V lower, and the current in the MOSFET at idle will be the source voltage divided by the source resistor. That means the source resistor dissipates as heat the value of the resistance times the voltage across it squared. You can burn up a lot of power in one of these.
      With only tiny differences for transconductance losses, yes. If you're puzzling over these issues, yes, think of it as being identical.
      Yes. But there are many ways to get less signal voltage.
      This is actually calculated the same way that a CF output impedance is calculate for a triode, which is an equation I can't remember. The trick is this: the output impedance of a CF tube or SF MOSFET depend on the inverse of the transconductance. A 12AX7 tube has a trsconductance of something like 1.6mMho, or 1.6 ma/volt of change on the grid. A MOSFET worthy of the name will have a transconductance of 1000 - 2000 mMho, or a thousand times more, so the output impedance of a MOSFET SF is a thousand times lower, typically.
      This is so much lower than a tube CF that it makes the source impedance relatively unimportant unless you're trying to do stuff like drive low impedance reverb tanks or speakers from a single SF stage. You aren't, are you?
        I almost understand .
        1. The source resistor sets the idle current for the mosfet. How much would be the max current?
        - In the case of the triode stage, the max possible current is set by the anode resistor.
        2. The output impedance is... not dependant on the idle current of the mosfet, nor the output voltage swing..
        Lets put an example why I am asking these:
        At the moment I have a tiny transformer to supply a double triode and probably two mosfet followers. Transformer is rated 250v AC, 10mA.
        Say I want to set 100k anode resistor (played a bit with the load line), 300v DC rectified.
        This is 2 x 3mA current for the double triode. This should be the max possible consumption, regardles of voltage swing.
        (as far as I get it, the anode resistor limits the max possible current)
        There are 2mA per a mosfet left. This is the total allowed curent. Wether it is the max current or iddle current, I don't know .
        The first mosfet follower is supposed to drive 100k Zin stage.
        The second is supposed to drive 4 stages with 100k Zin in parallel. I guess, the total load impedance should be 25k. Say 20k .
        Would that 2mA suffice...
        Just using ohm's law: 1,227352 v RMS (3,472v peak to peak) / 20k (worst case) = .. it will suffice . If not missing something.
        NOTE: the figure I am getting (0,0613676 mA) ^ is added on top of the 2mA idle current ??
        Voltage attenuation is next thing..
          Since we're on the subject here's a practical question from few days ago. On the pic below is an LND150 based FX loop also know as Metro Zero Loss FX loop. There's no CF there but the first stage is wired as inverting feedback amplifier which has a very low output impedance assuming the role of a CF.
          So after firing this thing up I measured 2 Volts at the send stage drain which is not normal. At the other end of the 100k resistor voltage was 254V which indicated ~2.5mA of current draw which is strange. After replacing components and scratching my head for couple of hours without any result I added a 1M resistor from gate to ground and very slowly the voltage at the LND drain in question went to 220V while at the other resistor's end to 305V. The only thing missing from my build is that R4 220k resistor.
          So I was wondering what happened and why? Shouldn't the loop work without that resistor to ground as per schematic?
Name:	ZL loop - Rev 3 sch.jpg
            I think that's the answer. Without R4 (or your 1M) the gate of VT1 has no DC reference to ground.
              1. The source resistor sets the idle current for the mosfet. How much would be the max current? - In the case of the triode stage, the max possible current is set by the anode resistor.
              Note that what you say is true if the active device, tube or MOSFET, is shorted. Then the current is just the power supply divided by the resistor. It does limit the max possible current, but you'll probably never see that current.
              Most 12AX7s can't really conduct more than 1-2ma no matter what you do to the grid, and they can't really "saturate" like solid state devices. As a practical matter, a triode with a 100K anode resistor from 300V will see on the order of 1 to 1.5ma.
              In the case of the MOSFET, it can sure act more like a short ciruit than a triode can, but you can also predict things better. The triodes will have their anodes at a voltage between 90 and 250V, set by the DC value of the cathode resistor for the triode. Let's say you set that to 150V by careful tinkering.
              The MOSFET gate will be at that same voltage; I recommend using a 100R to 1K "grid stopper" right on the MOSFET's gate for other reasons, but that won't affect the gate voltage. The MOSFET source will stabilize one Vt down from the gate. Vt (threshold voltage) is what it takes to get an enhancement mode MOSFET to start conducting. This varies from device to device, but is trivially small compared to the plate voltage on the gate. So say the source voltage will be 150-5 =145V.
              Now you get to pick the MOSFET's current. You do that by saying "I want this MOSFET to conduct Xma at idle". X will be in the range of 0.5 to 2ma, depending on what you decide X is. Let's say 1ma. So the source resistor has 145V across it and 1ma through it. Georg Ohm says the resistance must be 145/0.001 = 145K. That's clumsy, if you don't have a full bag of 1% resistors, so pick either 140K or 150K.
              What I'm telling you now is heavily simplified, but I think that's what you need right now. Really, the output impedace does depend a little on the idle current and swing IIRC, but that's way down on the list of your worries. And it doesn't depend much.
              And this is the point where I started understanding your design needs. You're power supply liimited.
              Is that transformer's 10ma "RMS" or "rectified DC", and what kind of rectifiers and filters are you using. This can make for a biggish difference.
              On the other hand, you're probably only headed for 5-6ma, so you may be fine either way.
              See above. You're likely to only see 1-1.5ma per plate.
              You get to pick whether it's 1ma 1.5ma, or 2ma with your choice of the source resistor, and it's DC idle current.
              [QUOTE]
              Those are AC current loads. I'd give it a try with 150K source resistors, and see if the loads don't pulll down the signal level for you.
              You **might** get into a situation where the SF tries to pull up the output AC load but can't get enough current from the power supply. This will happen at bass frequencies first. And you could run the SF out of headroom with big enough signals., I'd say to try it before buying a bigger power supply.
                That might be bad. Don't know what to expect if it clips. (bass guitar)
                It would be nice if the amplitude is just limited and sinusoide is rounded, so that I get a compression .
                On the other hand, how to calculate these AC currents.. I simplified as just adding up to the idle DC current.
                Both cases (7v Rms /100k Zin, 1,2v RMS/20k), if I calculate currents Zin, it is < 0,1mA.
                The transformer is rated 250 v AC, 10mA.... + 6v, 600mA. I guess should be RMS.
                I calc it as 350v DC (250x1,414) bridge rectified +cap. Haven't tried it yet, but the calc is pretty much correct. For lower voltage transformers..
                Then I will drop it to 300v, with 2 resistors and 2 smoothing caps. (f.ex. 22uF)
                The tube I consider is 6n1p-ev (more like 12AY7, military grade "ev", NOS). So it mby can go closer to 3mA. Setting it with 100k anode resistor would yiled a bit more gain and a possiblitiy to swap with 6n2p-ev (12ax7 like)
                Btw, abt. the topology itself. Here we have valve CF without any grid reference or biasing whatsoever:
Name:	70DR103preamp - Copy.jpg
                But Blencowe suggests grid biasing (much like the GainFreak circuit):
                I will be happy to have it the simple way - just gate resistor added.
                The idea to have voltage divider at the anode resitor to attenuate signal..
                Keeping AC swing and current low.. Sounds good to me now .
                  I'm not sure what current you are trying to calculate here. If it's the total current the power supply has to provide then you could just add up the idle currents. These are class A amplifier stages. The power supply current won't change much between idle and full output.
                    Sounds reasonable, thx . A lot more need to consider and understand than ohms law. I ve been reading abt class A amps, but...
                      I was left with the impression that in theory the zero potential at the output cap should provide the "virtual earth" to the grid but in practice there was ~0.8V at the the grid which made the LND draw more current.
                        I was left with the impression that in theory the zero potential at the output cap should provide the "virtual earth" to the grid.
                        There's no resistive path to ground at the output cap so it won't necessarily be at zero potential. It will charge up to some other potential depending on leakage currents which is probably different from the 0.8V you measured with the meter connected.
                          Hi again. I tested my psu with 22k load on the HT and the heater of actual 6n1p tube.
                          The AC HT drops to 233v, which is ok. I can also test with rectivier/RC network and check the DC, then recalc the loadline and biasing.
                          But, the heater voltage drops to 5.7v AC. This is the lower allowed heater voltage.
                          According to the tube specs, it has steepnes of 4.35 ma/v (I guess for nominal heater voltage) and 3.2 steepnes for heater @ 5.7v.
                          This makes me reconsider the psu transformer.. If I want to really put 6n1p in proper operation.
                          (For 6n2p it seems ok - HT under 22k load is 251v AC, heater under filament load is 6 v.)
                          So far so good. Moreover, I found that Rod Eliot has solution for this (as well..) .
                          Voltage Followers
                          He claims the circuit has very low output impedance (330 ohm, R4) and very good driving capabilities.
                          But...
                          "The current limit is around 25mA with a 330 ohm resistor. "
                          How does he calculate this ?????
                          "Increase the value of R5 if you don't need the drive capacity provided by the 22k source resistor. Output impedance is not affected if you change the value of R5, but the ability to provide a high level signal into low impedances is reduced. The circuit above can provide well over 5V RMS into a 2.2k load impedance."
                          If R5 (source resistor) limits the max current (disregarding R4), 250v/22k = 11,36mA....
                          How is that calculated?
                          My reasons are again - power supply limit - I can order 15VA transformer, giving 40mA for HT and 700mA for heater.
                          Is that correct, that the circtuit above draws 25mA ??? How it is possible?
                          If it is correct, how to halve the max current? Changing R5?
                          "Increase the value of R5 if you don't need the drive capacity provided by the 22k source resistor."
                          Since I don't know how these 25mA are calculated (HT - 250v), I don't know how to set the circuit to draw half the current .
                          Except - building a prototype and test..
                            But...
                            I guess the FET needs about 4V Vgs to turn it on. Subtracting 4V from the 12V zener leaves 8V across the 330R resistor so the current limit is 8/0.33 or around 25mA. This is only when sourcing current. It can't sink 25mA. I think it can only sink a peak current equal to the standing current i.e. 119/22 or about 5mA. 5mA peak limits the output voltage for a 2.2k load to 11V peak but it's limited to 10V peak anyway by the 10V zeners. 10V peak is about 7V rms which is 'well over' 5V rms
                            To set it to draw half the current double the value of the 22k source resistor. This will halve the voltage drive to a 2k2 load to 2.5V rms (I think)
                              This is correct but, as emosms says, even if the transistor is shorted, you cannot get higher current in this circuit than 11 mA. So the information about 25 mA limit is "general" and it applies to other values of R5 resistor and/or other power supply voltages.
                              Mark
