Hello. does it any beneffit using individual cathode resistors against a shared one.I keept Gingertube ideea regards unmatched pair and hogging current from one to another. But supposed driver tubes are perfectly matched static condition, class A working all the way,of course. what are the benefits of common mode against individual biasing, please ? The second question regards bypass capacitor over shared cathode resistor. Why is necessary as it did almost nothing in common mode just raising the harmonic distorsion ? Can You enlight me please? I want to refere strictly at this situation: perfect matched pair, perfect balanced inputs and no constant current generator. Felt someone any sonic diferences and can share his impression,please ?Thanks.
driver biasing question
Last edited by catalin gramada; 03-23-2017, 12:26 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."Tags: None
What do you mean by "driver"?Yes. that.s right.Power stage driver
As in:
- "can you explain what you mean by kerfludonic sound?"
-"oh, simple, something that sounds kerfludonic"
so please describe at some length what does a power driver do in an amplifier circuit.
FWIW at this moment I am visualizing 3 different circuits , any of which could be called "power driver" , so a little schematic would be even better.Juan Manuel Fahey
Ok I presented graphic the situations I asked above. Suppose the tube have very good driving capabilities in all 3 instances and have not care to save components. The inputs are perfectly balanced and tubes perfectly matched. I asked from a design choice perspective
Sorry for confused question. Power stage driver means a driver for power stage in my understanding. What is the correct term to use in english , please ? Thanks
Last edited by catalin gramada; 03-23-2017, 01:37 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
I think you're using the correct English term, it's just that power drivers are unusual in guitar-sized tube amps -- I think that is what caused the confusion here. I've only seen them in 6+ output tube designs like the Fender PS400 and Hiwatt DR405.
The other thing is that the power driver designs I've seen either use a transformer in the anode circuit or a cathode follower design driving the following grids. Topologies like you have drawn (anodes driving the following grids) seem unusual.
Hi. Thanks.I know what you mean as found more common to have enough voltage amplification from previous stages and buffering the inputs of power stages in case of "heavy loads" by own- in case of kt120 /150 or by summing.
But I.m particulary interested to drive by plates and curious to find the differences between situations I asked for in "real life". Thanks"If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by catalin gramada View PostOk I presented graphic the situations I asked above. Suppose the tube have very good driving capabilities in all 3 instances and have not care to save components. The inputs are perfectly balanced and tubes perfectly matched. I asked from a design choice perspective
Thanks Mike. Actually found the gain the same in common mode with shared resistor bypassed or not. but You-re right about distorsion. In theory at least the bypass cap should harmonics distorsions topped upLast edited by catalin gramada; 03-23-2017, 05:05 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by catalin gramada View PostThanks Mike. Actually found the gain the same in common mode with shared resistor bypassed or not. but You-re right about distorsion. In theory at least the bypass cap should harmonics distorsions topped up
But only for pure class A, and then only as long as the output tubes are in a linear portion of their transfer. I would think that outside of that restricted range, the scenario without the cap would distort more due to uneven current flow causing a time-varying NFB. But isn't that the opposite of what you've stated? Help me understand.If it still won't get loud enough, it's probably broken. - Steve Conner
Hi. I think is commin from better balance, maybe...as I found the bypass cap (large enough for experiment proposal - 1000uF) reduced the gain a little bit. It was a tiny fraction but still recordable.
Does it have any sense, please ?
I don.t know nothing about time-varying NFB (pretty ignorant in this sense) Thought negative feedback is a voltage matter and from this point better balance helps a lot as time assure current consistency over shared resistor wich becomes common mode. These are my thoughts aboutLast edited by catalin gramada; 03-23-2017, 08:57 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
with or without bypass cap output shows no big differences here at least at 20khz square:
have to play little bit maybe find some mojo in between. Thanks guys
PS: I still did not understood for what reason to choose one against the other as the amp works the same in both circumstances and is stable. Maybe will do a difference in overdriving condition but is not the case cause it is a clean kt120 power amp projectLast edited by catalin gramada; 03-23-2017, 11:29 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
...Last edited by catalin gramada; 04-03-2017, 05:12 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
