Hi There,
Been wiring a single channel of a Bandmaster AB763 into an old Hot Rod Deluxe chassis. (Tremolo, No reverb - Normal channel removed).
I've realised I've overlooked something I have to correct.
The Normal And Vibrato channels feed the PI each by a 220K resistor which I believe forms a voltage divider. By removing the normal channel I need to adjust the value of the 220K resistor on the Vibrato channel, yes?
For reference I think the Vibrato is feeding ~275V and the Normal is feeding ~265V according to Fender schematic. So PI is seeing about 135V? SO voltage this is what I need to maintain?
