So... I'm thinking of using a used tube amp transformer designed for countries with 100v mains in the USA. I'm thinking the major issue is the filament voltage will be about 7.2vac. Sticking a couple of diodes in the filament string will bring it down to 6.6 vac. Anything wrong with that? Should I even bother?
Using foreign 100v mains transformers for builds in the USA?
A lot depends on how closely the original transformer iron/copper designer ran the iron to saturation. If he got too close, you could be saturating the primary and see overheating and transformer death.
If it were me, I'd use a bucking transformer ala the Vintage Voltage Adapter to knock 20-24V off the incoming 120-124V and feed the transformer the 100Vac it was designed for.
It's perfectly OK to feed a transformer winding less voltage than it was designed for. Feeding it more than it was designed for brings the possibility of saturation and overheating.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
Originally posted by olddawg View PostSo... I'm thinking of using a used tube amp transformer designed for countries with 100v mains in the USA. I'm thinking the major issue is the filament voltage will be about 7.2vac. Sticking a couple of diodes in the filament string will bring it down to 6.6 vac. Anything wrong with that? Should I even bother?
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
Originally posted by nosaj View PostWhat is your reasoning for it? What do you hope to accomplish with it? just curious.
nosaj
Since saturation can be done only from a primary, try it with just the transformer hooked up to your local flavor of AC, leaving the secondaries open. Measure the no-load primary current and see if it's excessive. You might be able to tell quickly whether to go to the trouble of installing it or not.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
Originally posted by Mick Bailey View PostMost newer (90s onwards) Fender amps here in the UK run way over on their heater supplies. I regularly measure around 7.5v and they've been running like that for yearsOriginally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
If the TX is made for 100VAC 50Hz, the core flux will be the same at 120VAC 60Hz, so you should have no problems using the transformer, but at 60Hz only, and it the transformers you have are made for 50Hz.
Your secondary voltages will be 20% high
