Output Z
  • Output Z
    Could someone be so kind as to help me calculate two output impedances?
    1:
    A capacitively coupled 6V6 with Va of 150v and 5k Ra and 250 Rk.
    2:
    A IRF820 in follower config. Vd of 320 and Rs 100k.
    THANKS!!
    1:
    2:
    THANKS!!
    1:
    Real approximately, 5K. I expect the plate impedance of the tube to be several times that, so ignore it.
    2:
    The forward transconductance is 1.5 S, according to some data sheet from the web, at something over an ampere, I believe. So .66 ohms at that current. I bet it is higher at the current you will run, but I did not find enough info.
