Tube breadboard sockets
These are great for experimenting.
1SET 9pin B9A tube test diy Experiment prototyping pcb for EL84 ECC83 12AX7 EM87 | eBay
Breadboarding sockets and components were a really big thing that largely disappeared after the 1930s. Whole radio sets, sometimes quite complex, were built using them. They mainly had screw terminals and were made so that the home constructor could build an amp without soldering, using square-section, solid-core wire. Components were expensive back then, so they made good sense when you wanted to rebuild a radio or amplifier or use them for something else. Even resistors and capacitors had screw terminals. I have some odd-looking rectangular pieces of insulating material with a terminal at each end. It took me quite a while to discover these are grid-leak resistors - you drew a line on them in pencil for the resistance.
Those Pomona sockets look very similar to my vintage sockets, other than they have solder terminals. Plus, of course, B9A was many years later than the era I mention.
I don't know why I never though of making up some boards with a PCB mount socket and couple of terminal blocks similar to mozz's picture.
Originally posted by nosaj View PostFor bread boarding a circuit I'd always looked for the relay octal sockets. But take a look at the ones i found They are made by Pomoma XS series in 7,8, 9 pin sockets.
nosaj[ATTACH=CONFIG]43582[/ATTACH]If I have a 50% chance of guessing the right answer, I guess wrong 80% of the time.
