I have a 6V6 push pull guitar amp, cathode biased, cathodyne phase inverter with second half of 12ax7 used for tremolo. What I'm wondering is there a ball park bias swing, based on this amp, that any of you go for or would suggest going for?
With the tremolo intensity/depth on 10. Lets say, for ease of number, the amp is biased at 100% with the tremolo off. Would you try for a range of 50% to a 150%, or 75% to 125% or 80% to 120%?
I'm presently diving in a little deeper into the tube tremolo design pool, but for now, I'm wondering if there is a general rule of thumb to adjust the depth to so as not to burn the tubes up?
Between the amp being push pull and the tremolo raising the bias above and below the bias idle point, well, ya
