I'm working on a 5E3 Deluxe point-to-point layout. Please let me know if you notice anything amiss.
Guitar signal enters at the Bright Hi input jack at upper right. The signal splits and flows through both 68k grid stopper resistors to tube V1 pin 7 (preamp V1B grid). The signal leaves V1 through pin 6 (V1B plate) and a .01uF coupling cap to the Bright Volume pot. The coupling cap prevents high voltage DC on the plate from getting through to the volume and tone controls. The volume pot and tone controls bleed guitar signal to ground to control the volume and darken the tone. The guitar signal leaves the control circuit through the Normal Volume pot pin 3 and flows down to V2 pin 2 (preamp V2A grid). The signal leaves the tube via pin 1 (V2A plate) and flows through a coupling cap to the other side of tube V2, pin 7 (V2B grid). The coupling cap keeps high voltage DC off the V2B grid. V2B is the phase inverter and it splits the guitar signal in two. One signal leaves through pin 6 (V2B plate) and flows through a coupling cap to power tube V3 pin 6. A second, opposite phase signal flows out of V2B pin 8 (cathode) and flows through a coupling cap to power tube V4 pin 6. The power tubes' pin 6 has no internal connection serves only to hold the 1.5K grid stopper resistor. The signal flows through the grid stopper resistor and into the power tubes at pin 5 (grid). The guitar signal leaves the power tubes via pin 3 (plate) and flows into the output transformer primary winding. The signal couples with the output transformer secondary and flows out to the speaker jack.
