HT winding center tap question.
  • HT winding center tap question.
    Why do most guitar tube amps use a center tap on the HT winding? The tap is not grounded like the CT used for the heaters, but rather goes to a node created by two high voltage electrolytics.
    Wouldnt a simple single HT winding have done it?
    It's one way of ensuring the exactly half the HV supply voltage appears across each capacitor.
      I know Marshall uses a doubler circuit. Fender used sort of a half wave rect circuit with the CT grounded
        Have a read of The Valve Wizard
        Voltage doublers are something different https://en.wikipedia.org/wiki/Voltage_doubler
          Which Fender circuits are you looking at? Can you post a schematic? The Fender amps I see with a center tap are two diode full wave rectifiers. The diodes conduct on alternate half cycles.
