I have an Acus (made in Italy) acoustic guitar amp in for a sort of low end howling sound with nothing plugged in. It sounds like a low end feedback. All else functions on the amp. It's an SMD torroidal affair, and I usually consider this a board replacement, but I thought I'd have a look at the filter caps since one measured odd in circuit compared to the others.
Pulled the caps (two 4700uF/63v, and two 4700uF 35v), and measured. Three looked good pretty quickly, and one at first glance looked bad, but after a while of leaving the probes on it, the Fluke went from no indication to "Disc" (I think that is disconnect), to finally inching it's way up to a reasonable value close to 4700uF. Not really getting what was happening, I hooked one up to my DC supply to check for leaks. What happens next confuses me.
<+24v> to <+capacitor-> to <+ volt meter lead-> to <PS ground>
This measured 24v, regardless of polarity of the capacitor on all four caps. I've always tested coupling caps this way with good results, why is this time different?
Then I tried measuring current by:
<+24v> to <+capacitor-> to <400 ohm resistor> to <+ammeter lead-> to PS ground.
This time I measured ~42mA after a slow climb of about 40 seconds, with one cap taking maybe twice as long to get there.
Next test was reversing cap polarity
<+24v> to <-capacitor+> to <400 ohm resistor> to <+ammeter lead-> to PS ground.
This time each cap counted down to less than 0.10 mA, again with one taking longer than the others.
So, what am I seeing? Do I have a bad or suspect cap? And how come they are passing DC?
