I've built a DR-clone amp many years ago. It has a preamp channel with a switchable scoop tone stack and after many years I've found that using the lower scoop frequency can make the DR sound a lot like a 5e3. Of course I could just build a 5e3 tone stack and switch it in/out, but this approach also allows the range of tones that lie between the two tone stacks.
This "discovery" didn't come about from playing the amp. The setting combination was too unlikely - I never thought to try it. It came from a deliberate hunt for 5e3 tone using SPICE sims, so here are some plots that show the idea. The first is the 5e3 tone stack (with variable tone settings) and the second shows the switched DR stack with varied bass and treble settings. You can see similar rising slopes all through the mid freq range which are the defining character of the 5e3. After figuring out the needed settings on the DR based on the spice sims, I just dialed in the 5e3 tone on the amp I never even realized had it. More range in tone stacks seems desirable. I get the user interface problem in a long row of dials or sliders. Is a better way?
BTW - I've posted more about this at https://sites.google.com/site/string...xe-plus/drp-v2
