Choosing cathode bypass values
Originally posted by Dave H View PostI think it's more effective to switch the value of the coupling cap feeding the vol pot.
-Gnobuddy
Originally posted by nickb View PostHere is the corrected script:
In cases where (1/gm) is close to (Rk), there may never be a (-3dB) frequency at all - response goes all the way down to zero hertz without dropping 3 dB from the fully-bypassed frequencies.
I believe using (rp) is of marginal importance in most cases - I don't know of a valve where (rp) is low enough to be comparable to (1/gm). Perhaps this might occur in some ancient, low-transconductance, high-power triode output valve?
-Gnobuddy
Originally posted by Gnobuddy View PostYour script doesn't seem to agree well with LTSpice at all - it wants a 10.6 uF cap to match what LTSpice shows with a 1 uF capacitor. See screenshots.
-Gnobuddy
PS: The case where you can't get -3dB is detected and reported.Last edited by nickb; 07-29-2017, 10:08 PM.Experience is something you get, just after you really needed it.
Originally posted by nickb View PostYou entered the wrong data.
Nice calc! For your next trick, add display of the frequency response - easy enough to do with an HTML canvas element, but other things are calling me more urgently.
-Gnobuddy
Originally posted by Gnobuddy View PostAh. You removed my "gm" entry, and replaced it with "rp" and "mu", which can be used to calculate gm.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Welcome Gnobuddy! Stick around. I think you'll fit right in"Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostWelcome Gnobuddy! Stick around. I think you'll fit right in
Some reason when I read your post Chuck David Lee Roth Chimed in singing I ain't got Gnobuddy.
nosaj
Some days our brains are on it an other days they have left the building.soldering stuff that's broken, breaking stuff that works, Yeah!
Going back to the various formulae. (Sorry to be boring! )
Originally posted by Gnobuddy View Post... However, the formula itself, while very popular, is actually wrong. The "R" that matters isn't the external cathode resistor. It's the invisible "internal" cathode resistor, which has a value of (1/gm).
More accurately, the proper resistance to use is the internal (1/gm) resistance in parallel with the external cathode resistance Rk. Usually (but not always!), the parallel combination is dominated by the (1/gm) term, as Rk is usually much larger than (1/gm). So usually we can ignore Rk, and just use (1/gm). ...
1 / ( 2.pi.Ck ( Rk || rk ) )
Where rk = (Ra + ra)/mu
It is well known that mu = gm.ra and consequently 1/gm = ra/mu
rk is not equal to 1/gm
but rather rk = Ra/mu + 1/gmLast edited by Malcolm Irving; 07-30-2017, 10:36 PM.
-Gnobuddy
Charts? Done! Give it a go Cap CalculatorExperience is something you get, just after you really needed it.
Originally posted by nickb View PostYup. Wanted to stick to the RDH4 formula, to avoid confusion, funnily enough. Sorry about that.
You cannot enter values, which are not a multiple of 10. For instance mu of 41 or ra of below 10k. (Tried to use ra of 8.3k, as an example). Mu below 10 is also a no-go for the same reason. Also, there are a few small typos.
(2) Total effective plate load re_istance, k ohms - missing 's' in the indicated position.
(4) Cathode resistor, k ohms) - One ')' too many.
Originally posted by Thoriated Tungsten View PostThere seem to be some small buglets.
(4) Cathode resistor, k ohms) - One ')' too many.Experience is something you get, just after you really needed it.
Using the default values in Nickb’s on-line calculator (post #41): mu=100, Rp(total)=95k, rp=63k, Rk=1.5k and a desired -3dB frequency of 150Hz, we get Ck=0.96uF
Substituting these values into Merlin’s formula for the pole frequency (see post #40) we get a pole frequency of 215Hz.
At first sight there appears to be a discrepancy. However, I think it might be that the pole frequency is not an exact predictor of the -3dB point, when there is a zero close by.
Originally posted by Malcolm Irving View PostUsing the default values in Nickb’s on-line calculator (post #41): mu=100, Rp(total)=95k, rp=63k, Rk=1.5k and a desired -3dB frequency of 150Hz, we get Ck=0.96uF
At first sight there appears to be a discrepancy. However, I think it might be that the pole frequency is not an exact predictor of the -3dB point, when there is a zero close by.Last edited by nickb; 07-31-2017, 10:54 PM.Experience is something you get, just after you really needed it.
