Twin PA mod on VJ with dual PA master volume dial controls and electronic power scaling.
Now, if you're looking at the front panel, I'll go over this.
The switch on the far left is Operate/Stand-by. In stand-by, the yellow LED glows.
This is the BITE lamp for the filament power supply. If the main POWER switch is on,
and if this lamp does not glow, check the fuse on the Orange wires from the main power
transformer.
When the switch is in Operate, this provides High Voltage to the power tubes. The
red lamp is the BITE lamp for High Voltage. If the red lamp does not glow, check the
fuse on the Red wires from the main power supply.
Above the volume knobs are the BITE lamps for the pre-amp tube and both power tubes.
The pre-amp lamp will begin to glow after the pre-amp tube warms up ; 12 seconds. The
other tube power tube lamps will glow only when the power tubes warm up and the Power
Brake is turned up. The lables on the BITE lamps match the lables next to the tubes.
If one BITE lamp fails to glow, replace that tube.
Volume. Pre-amp gain. Unchanged.
Master Body control. This is the master volume for the 6V6 power tube.
Master Sparkle control. This is the master volume for the EL-84 power tube.
Electronic Power Brake. This control , controls PA plate current for both power tubes.
Set this control at 25% for over-drive tones.
Set this control to 75% for clean tones.
Set this control to 100% for sag and compression effects.
-g
transformer.
-g
