Originally posted by Leo_Gnardo
View Post
Adding a presence control to a Deluxe AB763 type circuit that didn't have one
Originally posted by Sarah View PostIf it is simple voltage divider you can easily go for the calculations from a calc like this. But for the complex cases you have to hook over the manuals one by one.The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
Hey! Leave Sarah alone. She's only trying to lend her expertise on how to handle loads. Incidentally... Hooking through all the Manuals could be a hell of a task south of the border. I (and the Manuals of the world) wish her luck."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostTo some degree the LTP PI doesn't sweat being elevated, within reason. But it's true that the more you elevate, the more "working voltage" is subtracted from the swing because it's now on the cathode instead of the plate. For an amp like the Bassman, with it's 10k tail that extra 5k elevation (now a total of 15k) was determined to be an acceptable loss of working voltage. But the BF type amps use the substantially lower 47R additional elevation. The designers had their reasons I'm sure and how much difference another 5k elevation added to the 22k to 47k tail of the BF circuits is probably no big deal, but I chose the 1k NFB shunt value just to play it safe, tonally. There is no safety issue with the 47r, 1k or 5k values. Anyway... A 1k shunt only changes a 22k tail elevation to 23k. Mice nuts. So that's what I did. The appropriate cap value would then be .47u for the same response as the Bassman (lots of upper mids) but .33u is nice too and might sound sweeter and less aggressive for a BF type amp (IMHE).
I'm thinking that if you resize the presence cap properly then the amp would sound great / not that different from before.
As fun as an exercise like this is from a design standpoint, I have to ask -- why is a presence mod necessary for an AB763 Fender circuit? They're already bright enough because of that bright switch. If anything, they're too bright and benefit from a smaller bypass cap on the volume pot, and flipping that bright switch on/off gives a lot of tonal change. I never thought of a presence as necessary in the circuit.Last edited by bob p; 10-04-2017, 11:14 PM."Stand back, I'm holding a calculator." - chinrest
Originally posted by Chuck H View PostHey! Leave Sarah alone. She's only trying to lend her expertise on how to handle loads. Incidentally... Hooking through all the Manuals could be a hell of a task south of the border. I (and the Manuals of the world) wish her luck.
I wonder if that link leads to a special offer on sports team jerseys. Bet you half a peach it does.This isn't the future I signed up for.
Originally posted by Leo_Gnardo View PostI wonder if that link leads to a special offer on sports team jerseys. Bet you half a peach it does.
A) No chicks post here (ok, I suspect one or two, but they never came off like a bot)
2) That calculator is only vaguely related to the subject by virtue of being electronics related. Clearly just an insertion maneuver."Take two placebos, works twice as well." Enzo
... this is one case where I'd gladly accept some insertion loss."Stand back, I'm holding a calculator." - chinrest
Originally posted by bob p View Post> Clearly just an insertion maneuver.
... this is one case where I'd gladly accept some insertion loss."Take two placebos, works twice as well." Enzo
Originally posted by mikepukmel View PostHow can a bot sign up, react to the signup, and post? Don't they have to go through those "Im not a robot" photo clickey things?This isn't the future I signed up for.
Originally posted by bob p View PostI did some number crunching last night but didn't get around to posting. What's interesting about this is that an AB763 DR uses 470R bias on the PI, 22k for the tail, and 47R for the shunt. Adding these up you get a total of 22k517. If you change the 47R shunt resistor to 5k as was recommended earlier, that brings the total cathode resistance up to 470R + 22k + 5k= 27k470. What surprised me was that the AA763 DR used 470R bias + 27k tail + 47R shunt = 27k517. So the AB763 with the 5K shunt mod ends up having about the same total elevation as the AA763. As it turns out, if you crunch the numbers through a PI gain calculator there's no real change to write home about when it comes to PI balance or output. This makes me wonder why Fender went from Rk=27k in the AA763 to 22k in the AB763. Is there a signficant difference? I've never compared them.
As fun as an exercise like this is from a design standpoint, I have to ask -- why is a presence mod necessary for an AB763 Fender circuit? They're already bright enough because of that bright switch. If anything, they're too bright and benefit from a smaller bypass cap on the volume pot, and flipping that bright switch on/off gives a lot of tonal change. I never thought of a presence as necessary in the circuit.The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
gain calculations -- just google for LTPI gain calculator and you'll find what you need. just enter the numbers and click calculate. sorry, but i can't post the actual numbers, as i did them on a piece of scrap paper and we've already had our garbage day.
here's one:
https://www.ampbooks.com/mobile/ampl...g-tailed-pair/"Stand back, I'm holding a calculator." - chinrest
Originally posted by bob p View Postgain calculations -- just google for LTPI gain calculator and you'll find what you need. just enter the numbers and click calculate. sorry, but i can't post the actual numbers, as i did them on a piece of scrap paper and we've already had our garbage day.
here's one:
https://www.ampbooks.com/mobile/ampl...g-tailed-pair/"Take two placebos, works twice as well." Enzo
