Input Capacitor??
47uF in series with 1M is nonsensical high.
Way more reasonable would be something between .0047 and .047uF .
And definitely not an electrolytic; besides being too large, any possible DC leaking from, say, a pedal or guitar preamp would be positive relative to ground ... so that capacitor would be reverse biased, lossy, and definitely not doing what it would be supposed to do.
MAYBE it´s a typo and original design required 45nF there.Juan Manuel Fahey
Thanks and no, they are certainly 47uf caps. There's one on the effects return as well.
I compared this schematic to a Soldano Hotrod 50 which is what it's based from and they are nowhere to be found in that amp. I went ahead and plucked them, and jumpered the traces. The result is a more forward detailed, less bloated tone. I wonder if they did this to make the amp sound worse than the Soldano??
Thanks fellas.
http://schems.com/bmampscom/soldano/...100_hotrod.pdf
Originally posted by m1989jmp View Post
In this thread ^^ Enzo says "The input cap is there to keep DC off the tube grid. Imagine if you have some effect pedal that has a few volts of DC offset at the output. Now how will your amp react if the input stage now has +5v there? or -5v there? A largish value cap that passes signal to the grid but blocks DC, solves that problem."
Then Merlin indirectly says "I find that hard to believe, considering all pedals have an output capacitor already! An extra cap at the input of the amp would simply reduce the effective coupling capacitance a tiny bit (assuming it has a large value)."
Anyway, why would a pedal have a DC offset or how common is that? I never thought of a pedal passing anything to an amp other than an AC signal.
the reason I ask is because if there is a DC offset it seems like that would add hum to the noisefloor as well as affect bias.
So if some pedals cause hum in noisefloor to increase I guess an input cap would be good for that. But is that how it would actually work?
I find pedals to typically increase hiss in noise floor rather than hum, but just wondering
I wouldn't say it is common, but they are out there. Cheap insurance. I don't expect 5 volts of DC, but half a volt? A lot more likely. And going right onto a grid it would certainly change the tube operating point.
Is it necessary? No, Fender never used one for the last what 70 years? I was just explaining why someone WOULD put one there. I see the reason, whether or not someone thinks it is worth the effort is a separate question.Education is what you're left with after you have forgotten what you have learned.
No, but would cause bias shift.
Considering typical first triode bias is between 1.2V and 2V something, anything above, say, 50 or 100mV will be quite noticeable.
Full 2V or more will straight cause tube cutoff, either polarity, because plate will either be at ground or full rail voltage.
Most pedals have an output cap for the very good reason that they are fed 9V single supply, so in principle output should idle around 4.5V , say between 2V and 6 or 7V , all way beyond what´s needed to cutoff or block next stage is left free to reach it.Juan Manuel Fahey
