The tail resistor is indeed 220k. I need to measure with the scope, but I think the LTP is enough to drive the KT88. There is no NFB loop around the power amp. Should I put it?
I removed V1 and V2, and the oscillation still there. If I remove V3 or V4 it dissapears. Then, I decided to leave all the tubes and start to remove the plate voltage. So, if I also removed the power for V3 at R31, the oscillation still there. Same case if I remove the power for V4 at R33. Another thing about V4, only half tube is used. The other half is no connected, but the fillament at PIN 5 is connected.
