Originally posted by bob p
View Post
1N4007 quandry
When the 1N4000 series was first conceived, it was >hard< to make 1kV junctions. So the high voltage ones did sell at a premium, and you only bought as much high voltage as you really, really needed. As processes got better, and making 1kV junctions got easier, I ..suspect.. the manufacturers of only trying to make 1N4007s and sorting out the lower breakovers to sell as the cheaper parts. Eventually, they may only try to make a few voltage grades, or maybe only one. Those datasheets ever mention a maximum breakover voltage. It may be that all 1N400x parts now do over a kV. Or a couple of lower ones. Hard to tell.
It's important to remember that we're looking over a gap in time about the same as the gap between the first electrical utilities EVER and the second world war. Lots of things change.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
I'll bet if JM measured the breakdown of his 1N4002s they'd all be over 1KV.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
Randall, there was never a reason you as an individual needed to buy 1N4001 or whatever, 1N4007 will be fine. Some industry contract though could specify a "low voltage" type, so they make them available.Education is what you're left with after you have forgotten what you have learned.
This sounds similar to what I had heard was done with CC resistors back when... So maybe it's not that new?
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
Aeons ago the 1N4001,2,3 had lower capacitances and more importantly lower reverse recovery charges than 4007, so it made sense to use lower volatge rated one in some applications.
After the switched mode revolution of the '80s and '90s all of those landed in the ultra-slow department and are only used for up to 400Hz switching.
Originally posted by picturevalve View PostI seem to recall an amp. I fixed which used 1N4004 diodes as bias compensators, they were thermally connected to the driver transistors. I forget the amp or the config., but the spec was 1N4004 due to their temp. coefficient.
Originally posted by Dave H View PostThe temperature coefficient of a PN junction (Vf or Vbe) is about -2mV/deg C. Either Diodes or a transistor can be used for bias compensation. I've used a TO92 transistor stuck with thermal compound in a hole in the heatsink. It's easier to fit than a string of diodes.
Whether this is the case for modern manufactured devices, I do not know.
Originally posted by Dave H View PostThe temperature coefficient of a PN junction (Vf or Vbe) is about -2mV/deg C. Either Diodes or a transistor can be used for bias compensation. I've used a TO92 transistor stuck with thermal compound in a hole in the heatsink. It's easier to fit than a string of diodes.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
