Over one shoulder I hear "just buy an existing cabinet. These projects always involve more research, money, and time than you anticipate." Over the other shoulder I hear, "So what, you always get yourself into these kinds of projects and always end up better for learning something you didn't know in the process. Besides music is an ultimately an acoustic event, you know much less about acoustics than you do audio electronics. Plus, the voice over your other shoulder underestimates just how cheap you are." Both these imaginary voices make cogent points, but the second one is right. I am cheap. But, I also do think speaker enclosure is important and traditional guitar speaker cabs do little to compensate for the beam type focus of upper middle and high frequencies.
Some people choose the best speakers for their cabinet design. I am approaching the cabinet design using brand new Eminence speakers I got at a great price. I have two 12" Eminence Red Fang 8Ω/50W speakers I've been wanting to use. I have 4Ω,8Ω, & 16Ω outputs on my amp, so I have flexibility in load impedance. Clean sine wave output is no more than 18W, but it clips early and relies on the guitar volume for cleaning up the signal. So doubling the power output still gives me some headroom with one speaker, so I would like to build a 1X12" cabinet, but I'm open to building a 2X12" if there is a good reason to.
I'm looking for some advice to get started. Does anyone have any expertise in this area who can help me interpret the Thiele-Small data and perhaps advise on some helpful software available, etc.?
Here is the relevant data:
here are the specs and Thiele-Small parameters:
Specification
Nominal Basket Diameter 12", 305 mm
Nominal Impedance* 8 Ω
Power Rating*
Program Power N/A
Watts 50 W
Resonance 97 Hz
Usable Frequency Range 80 Hz - 5.2 kHz
Sensitivity* 102.5 dB
Magnet Weight 35 oz.
Gap Height 0.31", 7.9 mm
Voice Coil Diameter 1.75", 44 mm
Thiele & Small Parameters
Resonant Frequency (fs) 97 Hz
DC Resistance (Re) 5.72 Ω
Coil Inductance (Le) 0.39m H
Mechanical Q (Qms) 13.39
Electromagnetic Q (Qes) 0.74
Total Q (Qts) 0.7
Compliance Equivalent Volume (Vas) 39.4 liters / 1.39 cu.ft.
Peak Diaphragm Displacement Volume (Vd) 24.9 cc
Mechanical Compliance of Suspension (Cms) 0.1 mm/N
BL Product (BL) 11.1 T-M
Diaphragm Mass Inc. Airload (MMs) 26 grams
Efficiency Bandwidth Product (EBP) 131
Maximum Linear Excursion (Xmax) 0.48 mm
Surface Area of Cone (Sd) 519.5 cm2
Maximum Mechanical Limit (Xlim) N/A
Mounting Information
Recommended Enclosure Volume
Sealed Acceptable
Vented Acceptable
Driver Volume Displaced 0.079 cu.ft. / 2.24 liters
Overall Diameter 12.03", 305.6 mm
Baffle Hole Diameter 11.07", 281.2 mm
Front Sealing Gasket Yes
Rear Sealing Gasket Yes
Mounting Holes Diameter 0.25", 6.4mm
Mounting Holes B.C.D. 11.59", 294.4mm
Depth 6.2", 157.5 mm
Net Weight 8.8 lbs, 3.99 kg
Materials of Construction
Coil Construction Copper voice coil
Coil Former Nomex former
Magnet Composition Alnico magnet
Core Details Non-vented core
ps. if I were a betting man, I would think my man JM Fahey has old school tuning tricks and done some cabinet design over the years. Yes?
Specification
Power Rating*
Program Power N/A
Watts 50 W
Resonance 97 Hz
Total Q (Qts) 0.7
Sealed Acceptable
Vented Acceptable
