Hi,
I am working on a design right now which is largely based on the 5G9 Tremolux in the tremolo and power amp sections. For various reasons I am using all octal-based tubes. I am planning on using a 6SL7 for the tremolo tube in order to have enough gain for the oscillator. Chassis layout dictates that the other 6SL7 be used as the cathode follower in the tremolo circuit. Looking at the datasheet I see that the heater-cathode maximum is listed as only 90 volts. Elevating the heaters is no problem, but I'd be reluctant to go higher than say 60 volts. My question is would the cathode follower function adequately if I used a very low supply voltage to the cathode, say 150v or so? The 5G9 schematic shows 260v on a 12AX7 at this point.
Any ideas would be much appreciated. The fact the the 6SL7 oscillator has higher plate current than the 12AX7 makes me hopeful that a little loss of performance in the cathode follower might not be such a problem, but I don't really know.
Thanks,
Andy
Thanks,
Andy
