Id like to put the ability in to adjust bias individually on each output tube. Not sure Im on the right track. I think I need to increase the value of the 56K resistor so that the voltage into the pots is higher (larger negative), then feed that value into separate adjustable voltage dividers for each tube. I poked around on the net, didn't see a ready made solution. They all seem to have one pot for both tubes.
![Click image for larger version
Id like to modify values so that I can use off the shelf 10k bias pots (recessed screw) can't find other values.
The hard part is not knowing the current, so I can't use voltage divider and ohms law calculations.
