Hey All,
I'm trying to dump some signal in a build, using the voltage division trick like all those uber-gain amps do, using some high-value resistors. I've read that series resistance can add hiss, and that's what I'm getting: LOTS of hiss, not affected by any of the controls and that wasn't there before I added the voltage divider. So I'm still experimenting with ratios, but I'm wondering - how low can I go for the values, in an attempt to cut the added noise? Most values I see used are between 220k-1M. But could I go lower? Like a 100k & 50k? It does seem as though the hiss gets less with lower values; I also notice some amps add a small cap in parallel with the resistor - is that to assist with noise?
This is a fairly simple amp, basically a Fender Normal channel feeding an LTPI & 2x6L6s. It seems really hot (loud!) and I'm trying to tame that a bit. There's not much in the way of places to add the voltage divider, so right now I have it after the Volume control and before the 2nd gain stage. I tried adding it at the PI input, but that did some REALLY don my stuff... I'm thinking my only other choice is right BEFORE the tone controls, immediately after the 1st gain stage; maybe? Yes? No?
I'm open to other ideas, such as changing plate load resistors to a lower value, and other fairly simple tweaks. It's a real PTP build, so it's kinda rough doing radical brain surgery... Thanks!
Justin
Justin
