From your description, you have a lot more hiss than you should. Are you sure you do not have an oscillation?
To judge hiss level, plug in a guitar with 500K pots. Switch to one pickup, and turn the volume down just a bit to get 250K for the series and shunt legs of the divider (its an audio pot). This gives you effectively about 125K in series with the input (more at the pickup-cable resonant frequency) and should swamp everything including the input grid stopper resistor. You should be able to hear this hiss by turning the amp volume up if everything in your amp is as quiet as it should be using a proper design and good components.
(You can turn the guitar volume up and down to try and find the point with maximum hiss.)
