Hi,
I am building a replica for a Marshall 18W. The guy wants the TMB channel, with an active FX Loop and a Reverb effect. For the FX loop, I'm using a kit from Tube Town. It works quite straight forward.
The issue is that when I'm trying to plug the Reverb circuit, it does not work properly. As you can see in the circuit, I am taking the signal from the Master, then I use the Phase Inverter to mix the signals.
What am I missing here?
Any help will be very much appreciated
