quality of transformers
  • quality of transformers
    Speaking about quality of components ...
    How much is quality of transformers important in the sound of a tube amp? Given a required voltage is the difference between transformers hearable? Any experience? Is there any sound sample?
    OTs or PTs?
    "Given a required voltage is the difference between transformers hearable?", suggests you are asking about PTs. A beefier PT, at the same B+, will ideally provide a more consistent voltage when demands are made of it, improving dynamics. So I don't necessarily feel that the final voltage produced is the whole story. In reality, however, finding 2 PTs of the same spec, that actually deliver the same voltage is another matter, so it can be a task & half to A/B products.
      I mean both PT and OT ...
      the PT must have a 'reserve' of current when needed, for the dynamic, how is this indicated in the specs? Higher nominal voltage?
      thx
        B+ secondary current rating.
          I report here a piace of consideration in tone-lizard site, only a piece as example, if you want to read more:
          http://www.tone-lizard.com/Electronic_Parts.htm
          "... More iron increases the low frequency response and the transformer core will saturate a little less. Some transformers were advertised as having a nickel core that offered less distortion! Primary impedance influences power output and frequency response. Higher impedances yield narrower bandwidth, less distortion, and less output. ..."
          I understand that specs are not enough to describe the 'sound' of a transformer. Any experience with transformers substitution and sound changes?
            ...from my TGP posting on the same subject
            ...there's an equation in the old vacuum tube engineering books showing low-frequency response being proportional to OT primary inductance.
            ...from Section 15-31 in Henney (Ed.), RADIO ENGINEERING HANDBOOK, 5th Ed (1959), McGraw-Hill:
            L(pri) = Zpri / 2*pi*F(low)
            ...for example, if Zpri is to be 10K ohms (6V6?) and F(low) = 20Hz, then:
            L(pri) = 10K / 2*pi*20Hz = 80 Henry!
            ...the three most important OT characteristics are:
            1) Turns-Ratio (TR) = establishes the impedance transfer ratio from output into input.
            2) L(pri) = establishes the low-frequency cutoff.
            3) L(leakage) = establishes the high-frequency cutoff.
