Why do I want to use a choke in a power supply instead of a 10 cent resistor.
Chokes vs resistor
Voltage. Current.
edit: OK, my answer's a bit terse. But what you want probably can't be answered without considering a number of things, so let me try again:
Tone. Money. :sigh:
OK, I give up. Why do you want to use the choke? What output power, pedigree?If it still won't get loud enough, it's probably broken. - Steve Conner
In short: Pros: choke drops less voltage, wastes less energy to achieve better filtering.
Cons: it's more expensive, bulky.
Cons: choke drops less voltage and wastes less energy to achieve filtering.
Pros: Less voltage drop = higher voltage on the screens when more output power is the goal.
A choke has the advantage of dropping less voltage AND being able to do it at an impedance that insulates the screen grids from the plates. Sometimes, even with resistances over 1k, a resistor doesn't isolate the screens from the plates enough to prevent excess screen current as well as the IMPEDANCE of a choke on the AC load. That's just my experience and I'm willing to accept some schooling on the particulars (please, in fact). But... As mentioned it's part of a whole system. WRT guitar amps a choke isn't better than a resistor and a resistor isn't better than a choke. They are both design elements with particulars that are dictated by, and dictate other aspects of the whole circuit. I won't go into a long explanation about "sag", etc. But the resistor option has it's place. As does the choke. Often ignored is the importance of how a choke can hold a higher voltage on the tubes while maintaining a safe relative impedance to the AC load. This, I think, is really where a choke shines."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostOften ignored is the importance of how a choke can hold a higher voltage on the tubes while maintaining a safe relative impedance to the AC load. This, I think, is really where a choke shines.If it still won't get loud enough, it's probably broken. - Steve Conner
Just reminding e biddy has not told *where* would he use it ("power supply" is as generic and vague as can be) , power supply voltage and current rating, what kind of load is fed from said supply and what are design goals.Juan Manuel Fahey
In most guitar amp designs that we know and love the choke is between the plate and screen nodes. It's there to keep the screens at a higher voltage and in a steady state for more gain, lower sag and (thank you OTM) better filtering. A choke would then be a good choice when you're design allows for it's use without excess screen voltage and you want the above characteristics. A resistor would be a good choice where you want more power supply sag or, in the case of something like a class A amp where there is not much sag anyway, you just want lower screen voltages. "I" think resistors have come into fashion for many homebrew designs because:
1: They offer power supply sag in the absence of a rectifier tube.
2: This reduces overall cost because chokes, rectifier tubes and sockets are expensive.
3: Many power transformers are either salvaged or replicas of older designs and often supply high enough voltage to jeopardize the screens in typical HV rail layouts if a choke were used."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostIn most guitar amp designs that we know and love the choke is between the plate and screen nodes. It's there to keep the screens at a higher voltage and in a steady state for more gain, lower sag and (thank you OTM) better filtering. A choke would then be a good choice when you're design allows for it's use without excess screen voltage and you want the above characteristics. A resistor would be a good choice where you want more power supply sag or, in the case of something like a class A amp where there is not much sag anyway, you just want lower screen voltages. "I" think resistors have come into fashion for many homebrew designs because:
3: Many power transformers are either salvaged or replicas of older designs and often supply high enough voltage to jeopardize the screens in typical HV rail layouts if a choke were used.- Own Opinions Only -
Originally posted by J M Fahey View PostJust reminding e biddy has not told *where* would he use it ("power supply" is as generic and vague as can be) , power supply voltage and current rating, what kind of load is fed from said supply and what are design goals.
Originally posted by frus View PostWhat about Hiwatts then? They certainly didn't cut the costs...
Originally posted by frus View Post...and probably didn't want any sag (the resistor was like 500 ohm anyway)?"Take two placebos, works twice as well." Enzo
