I got a new Dagnall D2512 / TXOP00012 OT for a Marshall JT30 that I think has a weak original. It came with no documentation. I have ID'd the HT side with 76 and 77 ohms from CT, also I did manage to find a drawing on a site in the UK that says the secondary is higher gauge wire, and that rings true. However, I am not sure about the secondary terminals. There are three, ground, 8 ohm, and 16 ohm, but I am not sure which side is ground and which is 16 ohm. Following the way the original is connected with ground on the left I see left to center = 0.7 ohms, and left to right = 0.9 ohms. Going in reverse I see right to center = 0.4 ohms, and from right to left I see 0.9 ohms.
The second way seems more correct to me, but it is opposite of the original, which makes me wonder if the original is wired wrong?
