Building a scratch build and have a Champ OT sitting around gathering dust and don't have a reverb transformer available. Can I use this transformer as a reverb tank driver instead? The impedance would be off a little bit, but would it really matter when all I need is to shake some springs? I think the Fender Reverb Driver is: P-TF22921 with 25k ohms:8 ohms ratio. The Champ transformer would be 17.5K ohms:8 ohms.
Can I use a Champ P-TF22905 Output Transformer as a Reverb driver?
Originally posted by 5thumbs View PostThe impedance would be off a little bit, but would it really matter when all I need is to shake some springs?
Also I've often wondered how a reverb transformer would sound driving a speaker. One of these days I'm gonna give it a try. Can't be any worse than a Champ, right? As in, don't expect much low end.This isn't the future I signed up for.
Originally posted by Enzo View PostSImple enough, pull the drive end cable from the reverb pan, and connect it to a speaker.This isn't the future I signed up for.
I am building a combo chassis that is very tight. Reverb transformer has to be mounted on the back side with access to mounting covered by the tag board. So once I wire it in, it will be difficult to remove. If it had been as simple as "tack four wires" I would have done it and not have troubled anyone. I was just hoping that someone had experience doing this and tips on any mods needed to make it work.
Originally posted by Enzo View PostMAybe start with an attenuator, wouldn't want that watt to risk the speaker.
Originally posted by 5thumbsI was just hoping that someone had experience doing this and tips on any mods needed to make it work.Last edited by Leo_Gnardo; 09-26-2018, 01:21 AM.This isn't the future I signed up for.
Originally posted by mozz View PostSome champ transformers are 17k, other are lower, like 8k. Just use a 12at7 to drive the reverb. Be sure the tank is a low impedance input too."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostPretty sure there were no 17k Champ output transformers. They are all pretty much 8k. But since the Champ OT has a 4 ohm secondary you would double your primary impedance running it into an 8 ohm load.This isn't the future I signed up for.
And... Since this is build in progress you could omit the parallel triodes reverb driver and use a single triode instead. That would get you a closer match impedance wise and save you a triode for some other function. I used a 12dw7 for a single triode driver in my last reverb amp. The lower mu triode in that tube can make ample power for driving the tank and the higher mu triode is a good recovery stage. I got really satisfying results using a "standard" reverb transformer. You're Champ OT would be a better fit."Take two placebos, works twice as well." Enzo
I think the very first ones in the tweeds had 3 different transformers. The 17k is the smallest. I have one here from 1959 with problems(shorted turns). Guy was using a 8ohm speaker, i guess the voltage swings were real high. I think classictone list the 3 replacements.
